How to reverse auto unlock?
I selected ‘Enable auto unlock for this computer’ - how can I reverse this and require a password to be entered every time? Thanks
If you are using WD Backup, use WD Security Help at the bottom of the screen for instructions.
Cliff
If there were instructions in ‘WD Security Help’ I would have used them - is it too much trouble for you to send the appropriate instructions?
Now this psot is very helpful to me. As I also get the answer of queries related to me.
