I have a 3TB WD My Book external HDD. How can I control the spind down time or disable it?
I found this online but it is dated 2004: http://support.wd.com/product/download.asp?groupid=304&sid=17&lang=de
anything newer and is compatible with this drive?
Hello you can setup the sleep timer for your drive using the WD Drive Utilities app. Check the link below for the steps.
How to set up and use WD Security & WD Drive Utilities
http://wdc.custhelp.com/app/answers/detail/a_id/10408
thanks a lot man! that worked
Do you know if the WD Drive Utilities will install and control sleep timer for the latest external 3TB Elements drive? The Utilities are not listed in the download section for this drive.
Drive: WDBWLG0030HBK
Product Link: http://www.wdc.com/en/products/products.aspx?id=260
Downloads Link: http://support.wd.com/product/download.asp?groupid=307&lang=en
Thanks.
