Hello All.
I know that this subject has been covered in other threads, but trying to
find the exact info that I need is a nightmare.
First of all my system is:-
Sansa Clip 8Gb
Firmware version, 02.01.16F
Windows XP SP2
Windows Media Player 11
I have tried every way and every suggestion that I can find on this
forum to get XP to recognise the Clip in MTP mode, without success.
MSC mode works OK, but I’m finding it impossible to create playlists.
If I use WMP11 to create and sync playlists, all the songs end up in a folder
called ‘Unknown Album’, and no playlist appears in the ‘Playlist’ option
on the Clip, I now have about 500 songs all jumbled up in ‘Unknown Album’
and the only way to select the song I want, is to scroll though them all.
If I use my sons laptop running Vista, a different set of folders appear. I can drag and
drop a folder of songs into the ‘Music’ folder, right click on the folder, and click
on ‘Create playlist’, rename and cut and paste the new playlist into the
‘Playlist’ folder, job done.
The playlist folder dosent even appear when connected in MSC mode, neither
do the folders of songs dragged in to the ‘music’ folder when using vista.
The bottom line is, how do I create playlists that the Clip will recognise, when
using MSC mode.
Thank’s
John.
