Gdrive mobile back up problems
I have a Macbook Pro running macOS Sierra 10.12.8
I run Parallels on it to run an application called Therapist Helper, a billing program. To back that up, I plug in the GDrive close the Helper app, and request a back up in the back up window that appears. Something that has happened multiple times with this and previous GDrves is that app says it can;t find the path to tho GDrive even though the only difference in the path address is the date. When this happens, the device cannot be seen by clicking “browse” within the app although it is visible in Finder. Sometimes, changing the initial letter of the path address works but mostly that just backs the app up to the Mac hard drive.
Any advice?
