Firmware Update
I’ll be using the Clip+ with Linux.  With the Fuze and original clip, it’s possible to do the upgrade by downloading the file manually and lpacing it on the device.
  • Will this be possible with the Clip+?
  • If so, where can the latest latest firmware be found?
Thanks!
Yes the manual firmware update process will be the same as the Clip or Fuze. The most current Clip+ Firmware is 01.01.05.
Forum Admin
slotmonsta
Are the Slotmusic and Slotradio To Go players capable of receiving a firmware update? I imagine that they might be, if they were designed to update the firmware when they see a firmware file in the root directory of a card inserted in the player.
Thanks!  Could we get a link to the current firmware stickied?
the clip+ was just released… i will not expect any update for it at this time
Are you planning to upgrade, and then downgrade?  :wink:
Hello everyone, i just want to confirm if there are any updated firmware released for sansa clip+ and how to get a copy of it, thanks…
i downloaded the lates firmware, copied the .bin file to the root directory, but the unit will just ignore the file. current version is 01.01.05a, latest version is 01.01.30 i believe. please help.
At least can we receive some estimated time remaining for the next firmware, or should we wait till summer?
Sandisk tend not to give ETAs anymore.  Just keep waiting.
