I have My Passport Ultra 1TB external HDD and when I try to open any folder inside the HDD, an error popping as “The request failed due to a fatal device hardware error”.
I have important documents in that HDD but am unable to access them… Please help me sort out this error.
Leesbrue09
Hi @Leesbrue09,
Please contact the WD Technical Support team for best assistance and troubleshooting:
https://support-en.wd.com/app/ask
When “the request failed due to fatal device hardware error” occurs, your device turns inaccessible. This error usually occurs while attempting to transfer/copy files and suddenly the Windows OS fails to recognize the input or the output devices.
To fix the error you can try the below DIY methods:
- Check the SMART status
- Run an error check
- Run CHKDSK scan
- Initialize the disk
Further, you can also check the below link to know more troubleshooting methods that can help resolving the issue:
Hope it helps!
