Is there a problem transfering songs from rhapsody to the fuze internal when a external memory chip is in the fuze?
I was trying to download to my fuze today and kept getting transfer errors. I shut the fuze off removed the memory chip hooked back up and the download went error free.
I was not trying to download to the external memory chip.
It is a 512 mb card that came preloaded with music. I transferred a channel from rhapsody and some music then received a error saying incompatible download. I then disconnected shut the fuze off reconnected same thing again. Then removed card and download worked.
Message Edited by blackhawkfan on 04-29-2008 10:19 AM
it sounds like it is trying to transfer channel tracks to your mSD card when it is inserted, even if you told rhapsody to transfer to internal. I think this was a problem with the old firmware.
can you check system settings > info and tell me what version your using? if it is 01.01.07, try upgrading the firmware to 01.01.11, it is posted in these forums. Then try again and see if the problem occurs.
I’ve had issues with the microSD card and Rhapsody also… I’ve taken to just popping it out before starting Rhapsody instead.
If you have a Playlist, and set it to Auto-Sync with the player, it will try and copy it to both the player and the SD card. Not an ideal operation. >.<;
