Hello I have a issue with Cruzer Blade - 8Gb
My laptop is Lenovo G570 - Intel Core i5, 8Gb Ram, Windows 8.1 Pro x64
The writing speed is limited to 3Mb/sec
I change the setiings, but there is no result on the writing speed
Some solution for this issue of mine ?
ylyl
2
I remember that SanDisk has never published the write speed of Cruzer Blade.
Are you testing your flash drive’s speed under a USB2.0 port?
Have you tried USB3.0 port?
Yes this is test of my memory stick.
The write speed was in the range 10-15Mb/sec before.
I don’t have USB 3.0 ports, only USB 2.0.
It seem’s that the flash drive itself have some issue… I test it on 4 more PC’s and the result is the same.
Time to get new one…
