Compatibility of SanDisk Extreme PRO microSDXC UHS-I Memory Card 512 GB
I want to buy the SanDisk Extreme PRO microSDXC UHS-I Memory Card 512 GB as a gift item for a mobile device. More specifically a Xiaomi phone. The model is probably Redmi Note 9 Pro or Redmi Note 10 Pro Max (not sure which one).
The Xiaomi website confirms that those devices are compatible with a 512 GB SD card.
As it is a gift item, I have no chance to check its compatibility. Some reviews on Amazon say this might have a compatibility issue.
So before buying, I wanted some expert opinion on whether this would be a wise buy. Thanks in advance.
PS: Is it OK for a DSLR that accepts SDXC?
Hi @Pratyya ,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
