For a starter I downloaded the manuals for both the Clip+ and the Zip, searched for the word ‘bookmark’ and ‘bookmarking’; zero results.
Questions:
- Which player is capable of?
- Can I bookmark any MP3/OGG/AAC I place in the Audiobooks/Podcasts folder?
Questions:
I thought I asked something simple. Too difficult, indeed?
There is no shortage of threads discussing bookmarking. I suggest you avail yourself of the Search function here. It works very well…
Forum search:
http://forums.sandisk.com/t5/Sansa-Clip-Zip/Bookmarking/m-p/289208#M3926
Google immediately found this:
You could also just experiment–no idea whether .ogg files will do that, so you could try and report back.
