Hi, :smiley:
I tested this new player and my old Clip+ in same conditions and Clip Zips gets around 10hrs. of playback and Clip+ 14hrs.
Is it normal ?
Thanks ;D
Hi, :smiley:
Is it normal ?
Thanks ;D
Well, that means a downgrade for me xddd.
Thank you ! :smiley:
The larger color screen on the Zip consumes more power than the 2 color OLED screen on the Clip+.
In playback I never turn on the screen
Sadly this doesn’t matter :c
I don’t know whether you’ve heard of Rockbox (3rd-party, open-source firmware), but if you really like the Zip as a player except for the run time, you might consider installing and using it. You might get better ‘mileage’.
Hi ;D
I use it already but in same conditions Zips gets 8hrs30min and Clip+ 12hrs30min
