16GB microSDHC?
Has anyone tried using a 16GB microSDHC card in the Connect?  If so, and it appears to work, how much of the card have you used (more than 8GB?)?
Thanks in advance.
In case anyone’s interested, a 16GB card appears to work fine.  I loaded a 16 GB card with 2913 songs, using 14.5 GB of the card.  I also loaded 382 songs into the Connect’s internal memory.  The Connect shows 3295 songs total, and all the songs appear to be playable.
Yeah!
