Does anyone know how to format it back to 16GB?
Thanks in advance.
Thanks in advance.
Make sure files are backed up (if still doable). Open My Computer with the stick plugged in, right click on that USB drive and select “format”.
Good luck.
Formating does not change the size of a drive.
Never has.
Tools such as Parted Magic change partition sizes, if the drive has the space to do so.
It would be helpful when people post problems they would post how they created the problem.
Nawww! That’d take all the fun out of it! ![]()
