Used portion cache always 0,07 GB
This is my old system that runs the cache disk fine. My newer system will not run it. I will post the specs later.
Summary
Operating System
Microsoft Windows 7 Home Premium 64-bit SP1
CPU
AMD Athlon 64 3700+ 38 °C
ClawHammer 0.13um Technology
RAM
2.00 GB Single-Channel DDR @ 201MHz (3-3-3-8)
Motherboard
nForce (Socket 754) 47 °C
Graphics
DELL 1905FP (1280x1024@60Hz)
256MB GeForce 7900 GS (BFG Tech) 40 °C
Hard Drives
29.8GB SanDisk SDSSDRC032G ATA Device (SSD)
466GB Seagate ST3500630AS ATA Device (SATA) 29 °C
Optical Drives
DTSOFT Virtual CdRom Device
Audio
Realtek AC’97 Audio
Operating System
Computer type: Desktop
Installation Date: 23 February 2012, 19:06
Serial Number:
Windows Security Center
User Account Control (UAC) Disabled
Firewall Enabled
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every Wednesday
Schedule Time 3:00 AM
This system will not run the disk cache at all.
Summary
Operating System
CPU
AMD Phenom II X4 940 46 °C
Deneb 45nm Technology
RAM
4.00 GB Dual-Channel DDR2 @ 400MHz (4-4-4-12)
Motherboard
BIOSTAR Group TA790GX 128M (CPU 1) 29 °C
Graphics
X223W (1680x1050@59Hz)
ATI Radeon HD 4800 Series (Sapphire/PCPartner) 50 °C
Hard Drives
932GB Western Digital WDC WD1002FAEX-00Z3A0 ATA Device (SATA) 40 °C
932GB Western Digital WDC WD10 EADS-00L5B1 SCSI Disk Device (SATA) 33 °C
Optical Drives
HSLWV HQ3G923 SCSI CdRom Device
TSSTcorp CDDVDW SH-S203N ATA Device
Audio
AMD High Definition Audio Device
Operating System
Installation Date: 20 July 2012, 06:49
Serial Number:
Firewall Enabled
Windows Update
Schedule Frequency Every Day
Windows Defender
Windows Defender Disabled
Antivirus
Antivirus Enabled
Company Name Microsoft
Display Name Microsoft Security Essentials
Product Version 4.1.522.0
.NET Frameworks installed
v4.0 Full
v4.0 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Environment Variables
USERPROFILE C:\Users\MrMazak
SystemRoot C:\Windows
User Variables
TEMP C:\Users\MrMazak\AppData\Local\Temp
TMP C:\Users\MrMazak\AppData\Local\Temp
MOZ_PLUGIN_PATH C:\Program Files (x86)\Foxit Software\Foxit Reader\plugins\
Machine Variables
ComSpec C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK NO
OS Windows_NT
Path C:\Program Files\Common Files\Microsoft Shared\Windows Live
C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
C:\Program Files (x86)\AMD APP\bin\x86_64
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static
C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin
C:\Program Files (x86)\HP\Digital Imaging\bin\
C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3
C:\Program Files (x86)\Common Files\Acronis\SnapAPI\
C:\Program Files (x86)\Windows Live\Shared
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
NUMBER_OF_PROCESSORS 4
PROCESSOR_LEVEL 16
PROCESSOR_IDENTIFIER AMD64 Family 16 Model 4 Stepping 2, AuthenticAMD
PROCESSOR_REVISION 0402
AMDAPPSDKROOT C:\Program Files (x86)\AMD AP
I removed bitlocker and it worked.  I had ExpressCache install and turned off Bitlocker. After the drives were decrypted and a reboot later, the ExpressCache software started working.
I’m using win8 and find that it resets to 0.07GB after I reboot.  It fills up during the up-time, but it won’t help reboot faster this way.
I have the same problem of 0,07 Gb of cache portion used.
Windows 7 Pro, 32bit, HD Seagate 500 Gb ST3500320S… No bitlocker, Windows Security Essentials, no RAID.
What can I do?
do you ahve any type of security software or any other software that would try to manage the storage?
My is the office PC, I installed only Microsoft Office 2010, Adobe Creative Suite, Visual Studio Express, and some other “serious” applications. My collegue has a similar PC with similar applications and the ReadyCahce works well. Isn’t there a log file that explains something? Thank you…
I do have very litle software installed and the only security software I have is Zonealarm antivirus + firewall free edition. I have disabled windows firewall and windows defender. I have added exeptions for expresscache.exe and expresscacheapp.exe in zonealarm even tried without any antivirus / firewall installed without success. I do not know of any other software that could interfer. Could it be that the express software does not have the right “permissions” or something. My user account does have admin status.
Its been a month, has the devloper looked into the Bitlocker issue?
bitlocker is suppose to be fixed in the next release. we dont have a date for relese yet though.
I am in the same boat of a useless ExpressCache installation as I must use BitLocker on my work machine. I am eagerly looking forward to this next release, or even a beta.
-a
So there is any solutions of 0,07 GB problem?
EasyCache is not compatible with GTP volumes (GUID Partition Table).
expresscache should work with GPT partitions. Can you share a little more regarding your comment?
Looks like the 1.1.0 version fixed the Bitlocker issue.
I installed the update to get up to 1.1.0 (1.0.100) version and it appears to be caching with Bitlocker turned on.
Good news!
I have managed to solve my “no caching” problem. I installed “EaseUS partition master” free edition and converted my dynamic disk to a basic disk and now everything seems to be working as intended. Hope this info helps anyone having the same problem.
I just converted my disk to dynamic and can confirm this causes the issue. I also used the same software you mentioned and was able to convert back to basic and caching started to work again. If any others are experiencing this issue try converting your disk to basic and let us know if it works for you.
After about 20 hour of copying important files, formating hard drive, I menaged  to convert my dynamic dysk to basic. “EaseUS partition master” does not help. I have to format drive and install system again and all of software.
But now, ready cache works well. And yes, there is no problem “cache 0,07 GB”, and system works faster, programs open faster. So finally i can see how it works.
Sadly,  it costs to much of me lifetime to repair SanDisk or ReadyCache issue. You should write better software…
So, most important: For all people who have problems with proper working of ReadyCache You must convert yours hard drive from dynamic to basic. For my knowledge, You cant convert it without loosing data if You have system installed on drive You like to convert.
Not sure why EasyUS partition master did not work for you but I tried it myself and it will convert dynamic to basic with absolutely no data loss.
Hi all,
I was having the EXACT same issue. I am running an AMD Phenom II Hex Core proc, 8gb ram, ASUS mb, fairly vanilla system. No raid as backups are done to an external drive. Product worked great until a few days ago. I thought I found the solution when I saw the post regarding Basic and Dynamic drives. Well, none of my drives were set as Dynamic.
I was going to uninstall/reinstall the software via CP. However, as not all programs have the option, I was pleased to see the “Repair” option. I thought what the hey, and gave it a try. Without even having to reboot (I just opened and closed the same programs a few times, and now the card is working great again. It was an immediate fix.
I hope this helps some others as I was about to start pulling hair out !
