ok, thank you
cheap wholesale usb flash drive
I listen to a lot of books on tape and have mostly used the various SanDisk players. Currently very happy with the SanDisk Clip Plus and am on the second one that is just now having problems making solid connection with the headphone jack.
I have found that the jack receivers become worn and I only receive sound through one of the channels. I’ve not found a true fix for this, mostly just considering them worn out, but have found that putting a rubber band over the headphone jack extended to the far corner puts just enough pressure for me to receive sound out of both channels. The rubber band works for me because I use a silicon case on which the rubber band can get a bite.
Would love to hear of a better repair. Or an oversized jack converter to add that extra contact pressure. I’ll give the Monster Headphone Replacement Cable Control Talk Universal Minid to Mini a try. Hopefully that or similar is still available.
Thats the exact same thing happening with me.Its very annoying but otherwise its great my model is the SanDisk Clip Sport MP3 Player
I think I got this bluetooth headset wireless very good quality, my friend bought this from Amazon and they all very happy for it, which REALL can work over 20hours, hope you guys will like it
