Sandisk Clip Sport?
@toehser wrote:
So, unless there is also going to be a “non-sport sport”…
There is. It’s called the Clip Zip.
@miikerman wrote:
But, that’s without a 25-hour battery and improved screen . . . .
True, but it remains a fine player, even 2 and a half years later. :wink:
But that’s without the alleged 25-hour battery and improved screen.
Fixed that for 'ya . . . and the screen is claimed to be larger, but not any bettter.
Time will tell. :wink:
Long time sandisk user.  I am on my 3rd Fuze V1 and have had several of the Clips.  The earphone jack and clip on my wife’s clip broke so like some others, we went to Best Buy to get a new one.  She didn’t want an Ipod and we saw the Sport and bought two of the 8gb versions.  I have to say, that I am quite dissapointed in it after a week of use.  I rockboxed one of my old Fuzes so I could use it instead of the brand new Sport.  The biggest disappointment is the fact that the internal memory and the card slot are separate in the database.  It has frustrated my wife greatly.    I am thinking of putting it away till they come up with a firmware fix or a rockbox solution.  Seems to me, that if somebody can get the bin file for the sport, that rockbox would be a simple fix as they already have working ports on the clip+ and Zip, which this sport is based on.
This was by design in this model. Do you like the increased battery play time (25 hrs.)? It’s a trade-off. I believe this is (at least partially) how SanDisk was able to squeeze extra play time out of it, by not being able to switch automatically between internal and external memory locations. This is especially relevant when you when you consider it has the same size battery but also has a larger LCD screen.
You want complete integration bewtween the 2 memory locations? Buy a Clip+ or Zip.
Separting the internal and external memory has no impact on battery life.    The difference in battery life is them updating to a newer processor that is a little bit more power efficient than the somewhat older AMS chip in the Zip.
At the anythingbutipod.com forum, a new Clip Sport user reported that after playing an audiobook for 24 hours, the Sport showed that its battery was still 1/3rd charged.
Time has told.   :wink:
To be fair, audiobooks are also very low bitrate files. With higher bitrate/quailty music files, I’m sure more battery willl be used.  That said, it is an encouraging sign.
Just got this thing home and I’m not seeing a lock function and no single button when held or just tapped will lock it. I listen to podcasts that are 1.5 to 2 hours long and an accidental bump results in some consternation. Does anyone know if I’m just missing it? If it doesn’t have a lock, it’s going back to best buy in the morning.
The screen isn’t better.  It’s larger and crappier.  I say crappier because the pixel density, which was quite substandard on the Clip Zip, is just as low now, several years later, when the standard has risen substantially for pixel density on displays.  It’s not even an LED type display anymore, it’s now an ordinary LCD screen.  If they could have feasibly stuck a 1" vacuum tube display in it, they most likely would have.  WTF SanDisk?
It’s basically the Clip Zip, minus some useful features, with slightly less intuitive interface.  But a bigger hard drive (which my computer won’t recognize)!!!
I went out of my way to gripe because, since the release of the Clip+, the most advanced, most perfect mp3 player ever created, the absolute pinnacle of media player technology in its time, SanDisk has, with each subsequent generation, listened to what the consumer loved about their device, and systematically removed those teatures from the next version.  Luckily, the Clip+ was SO amazing, even with the rate of degradation in 3 generations, the Clip Sport is still a great device.  It’s just tragic considering it could have been so much better.  Why SanDisk, Why?
Did any manage to get the device activated to play audible files? I had no luck in doing so. The device fails to be recognized by Audible Manager
so, let’s summarize the differences between Clip Zip and Sport, please.
what is size of the Zip screen, btw (in pixels and inches)? What about screen type (Zip/Sport)?
what kind of SoC does Sport have? AMS or some newer/different one? What about battery capacity in mAh (again, compared to Zip).
I hope Rockbox port (at 1st, unstable) will come pretty soon (with combined 1 database).
And last, any 1st reports on SOUND quality (compared to + and ZIp)? I think no one has mentioned it, yet.
