The books are from OverDrive. I do not have them on CD. The licenses are current.
I have the Clip set on automatic detection for the proper mode. I used the most recent firmware and WMP.
I’ll try setting the mode to MTP manually and download a new book and see what happens when I finish the one I’m currently listening to and then try the new one.
After I finish one book, another book won’t start. My use of “book A” was just a place holder, each time it was a different book.
I’ve downloaded two books into the audiobook folder (and in mtp mode). I’m currently listening to a book that I mistakenly downloaded into the music folder (I forgot to choose ‘advanced’ in downloading). When I’m done with it (currently in hour 6 of 18) I’ll go right to one of the books in the audiobook folder and see if it starts.
wow you really a audiobook fan, you go through books like knife through room temperatured butter!
regarding playback issue, I have a few troubleshoot questions:
when listening to the first audiobook, how do you procede to the next chapter (next parted file). do you navigate, or you allow it to auto skip.
After the first audiobook finishes, how do you begin playback of the next audiobook?
(sorry if this was already mentioned before) After the first audiobook finishes, does all audio playback stop?(FM, Music, voice record, etc)
Somethings to try:
Play the very last chapter of the first audiobook, and fast foward to the end, but let it play back the next few secs as if it played through the whole book. Does the next audiobook play?
After your first audiobook playback (full) and you can’t get the second audiobook to play, try going to voice record, make a recording, than stop (save or don’t save). than procede to the second audiobook. Does it play now?
If after the first audiobook finishes, and you can’t get the second audiobook to play, BUT the FM, or Music playback works, try going back to audiobook and see if it plays.
Sorry to bombard so many questions and possibel tests, just want to narrow down what could be causing the problem. Don’t feel obligated to try them all.
The player automactically cycles through each chapter in order.
I click on the back-arrow to the Music folder (remember that I have yet to listen to a book that’s in the Audiobook folder) and then click on the new book’s title folder and choose chapter one. I hear about five words and then nothing.
The last time this happened, I went and tried the radio and it did work.
I’ll try the suggestions that you made, but not until I get closer to the end of my current book. Thank you for the suggestions.
I have carpal tunnel in both wrists and can no longer garden, knit or cook like I used to. I fill my time with walking and reading as I find most television to be too mindless. I often read a book a day and listen to audiobooks during my public transit commute to work, 45 minutes each way. I also work near a track so I can go and walk and listen at lunch if I feel the need to get out of the office for a bit.
If I find that the problem continues after playing books in the audiobook folder, I’ll send it in for exchange. I haven’t had the opportunity to do that yet. The license has expired on my current book and I don’t want to mess about trying anything until I finish it. If it stops playing, there are 9 people on the waiting list for it and each one gets the book for a two week period. That would be a long time to wait to get it for a second time.
Also, everything in the past has been downloaded with the mode set automatically. The most recent download was done after manually setting the Clip to MTP and placed properly in the audiobook folder.
Everything might work right now, I just have to finish my current book and then I can experiment. Thanks very much for all your help. I’ll keep you posted.
Success! At least for the moment. Last night I finished playing the book (22 hours) that I had downloaded into Music and immediately went to the first book that I downloaded into the Audiobook folder (6 hours) and it played. The new book continues to play this morning. This is a good thing. I don’t know if the success is do to the MTP formating or the new folder option, but it’s working.
