@blackdog_sansa wrote:
WMP is a real PITA
Synching is a real PITA
Together they are …a bigger PITA
I learned this after about three weeks of extreme frustration when I first started.
No more WMP
No more playlists
No more synching
MSC and drag/drop just like you’re going to a USB flash drive.
I have a large music library back on the PC and there’s no way I would want to synch it.
Microsoft has cause so many headaches with all their garbage.
One other thing I’d advise: Every so often just backup your entire Fuze to the PC, music, videos and all. Just make a SansaFuzeBackup folder and copy the entire thing. Do this once a month or so. Worst case if you crash or have to re-format…everything is right there in one Copy maneuver.
As far as my Fuze goes…
"No more WMP
No more playlists
No more synching
MSC and drag/drop just like you’re going to a USB flash drive."
Completely agree on those points…If I must make a list, I use the Go List, and drag and drop ensures my album art, which is supplied by WMP to my music folders , actually makes it to my Fuze.
Now as far as my 8GB Clip…I still add and remove music from it with WMP(with the exception of any Ogg Vorbis or FLAC that I might use) , in MSC mode, because it’s simple, and album art doesn’t apply, and it’s nice to see just how much room is left when you’re deciding what to add to it. :wink:
