Hats off man… Even i was frustrated with the same issue. Now it works. Pls its still not working if i put that in MTP mode. Instead i have put that in MSC mode and ma sandisk player gets charged…
Regards
Ganesh S
Regards
Ganesh S
What happens when you put it in MTP mode? Is it just not charging? Or the Computer is acting funny?
I had the same issue and my FUZE is working like it was new.
Mabye I can help
If i changed that to MTP mode its behaves lik previous. Shows charging for a while and then the charging options stops. As a result battery gets empty. Couldn’t access internal memory yet…
Have you tried to reset it to the factory default settings?
Settings>System Settings>Reset Factory Settings
OR
Try blowing air in the USB port and cable there may be some lint or dirt.
Ususally with charging problems, is it plugged to the back of the CPU?
Ira
Im having a bit of a different issue. I got my Fuze and turned it on listened to it for a bit and it ran out of battery. I plugged it in to charge and it doesnt do anything. Because it is dead i cannot change any settings and it is getting no charge. Any suggestions?
Try a different USB port. Usually the ones in the back (on a desktop) put out more power than the front ones. If using a laptop, make sure it is plugged into AC power. But there are some laptops that simply don’t put out enough juice to both make a data connection and charge the device at the same time. In this case, you probably need to get an AC - USB charger.
My fuse has done that 3 times and what i will do let it plugged in on an external charger to the wall all night. By the nexed morning it’s reacted and ready to be used.
Thank you so much for very helpful advice. My problem appeared after installing a driver for a webcam. Strange coincidence. Everything is now back to normal. Thanks again. François.![]()
Thank you so much for this post. I was about to throw my mothers Dell Mini 10v against the wall or my Fuze on the floor. You saved me a lot of money so thanks again.
Thanks man! It worked for me too…!!
this worked as well with the sansa fuze + as well after norton remoted into my computer to fix their software and modified the registry. it corrupted the registry for the fuze+. thank-you very much no one else had a clue what to do and san disk wanted me to send unit to them to fix problem. isn’t outsourcing tech services wonderful!!!
All of a sudden my PC stopped recoginizing my sansa fuze- it doesnt even charge it- its not the usb ports- i’ve tried em all- and its not the cord because- i can use the cord with adapter and plug into wall and charges fine- HELP
It could still be the cord. The charging connection is separate from the data connection. If you are in MSC mode and still not connecting, it’s probably worth getting a generic cord for $3 from Amazon and giving it a try.
Make sure it’s a Fuze cord, NOT an iPod cord.
@scottpl390 wrote:
All of a sudden my PC stopped recoginizing my sansa fuze - it doesnt even charge it- its not the usb ports- i’ve tried em all- and its not the cord because- i can use the cord with adapter and plug into wall and charges fine- HELP
Have you done (or changed) anything that might have caused this? Like updating the firmware or formatting the player? Or any changes to your computer, like formatting, re-installing Windows, updating Windows, installed any new programs or attached any new USB devices (printer, webcam, etc.)?
I was among those whose Sansa Fuze suddenly stopped being recognized by my computer. Although the message still pops up, I have found a workaround that has returned the Fuze to functionality.
When this problem first started, I was using my old computer, with USB 1.0 ports and Win XP. As I said, I tried all of the solutions people had posted here and elsewhere. At first, plugging in and restarting the computer seemed to help. Then it didn’t help. Next I tried reinstalling drivers, fiddling with the USB controllers, but nothing really resolved the problem. When i plugged the Fuze into a computer running Vista, I’d get the same message, but I was able to restart the computer and the computer would recognize the Fuze and I could see my files. Recently, I bought a new computer with both USB 3.0 and 2.0 ports and Windows 8. I plugged in my Fuze and got the familiar, but disheartening message that the USB device wasn’t recognized. So I opened the Device Manager , selected “Update Driver” and started experimenting.
In the list of Devices, I selected “Other Devices” and selected the “other device” with the exclamation point next to it.
Next, I selected Update Driver Software. I chose “Browse my computer for driver sofware.” Next, I selected “Let me pick from a list of devices” and chose “Portable Devices.” In that list on the left were some familiar choices, such as Standard MTP device. At the bottom of the list on the left, I selected Microsoft. In the window on the right , after selecting Microsoft were two choices, I selected the one called “WPD Composite…” When I did, up poppped a warning that this option might not be compatible. Feeling lucky, I decided to install it anyway. And what to my wondering eyes should appear but my Sansa Fuze in all it’s glory. After the Fuze gets its new driver, it ends up defaulting to “MTP USB device.”
The down side of this workaround is that you will have to repeat the procedure of installing the driver every time you plug in your Fuze. It’s messy, but it works.
Or just use MSC mode and forget the MTP nonsense.
Tried that and unfortunately, it did not work for me.
You know the old saying, “there is more than one way to skin a cat.”
You might like MSC mode. Others do not. You may have your way of doing things that may work perfectly well for you, but it doesn’t always work that way for others. Just because you hate Win Media Player, or love, love love Rockbox, doesn’t mean everyone else has to follow you. Maybe instead of putting down one person’s solution to a problem you can either be gracious or, better still, just say nothing. I didn’t slam you or your solution. I prefaced my original reply to problem with the caveat that none of the other solutions presented had worked for me. I offer them only because someone else who finds him or herself in a situation similar to mine might find it helpful.
Let me repeat, since I started having this problem, I tried every solution listed here to no avail, including your blessed “switch to MSC.” None of them worked for me. I stumbled upon something that did, allowed me to keep my Fuze the way I like it. Perhaps my method may help someone else. Last I checked, this was an open community where everyone is allowed to offer his or her two cents. Here’s a nickel. Keep the change.
Whatever works for you.
Tapeworm was suggesting MSC because it usually works better, and the fact that you have to reload the driver every time you connect sounds pretty inconvenient.
Using the Fuze in MTP mode (or Auto with any recent Windows, which goes to MTP) makes it a virtual device for Windows, an extra step which is just one more thing that can go wrong. For many other users, switching to MSC made troubles go away.
It is quite odd that MSC doesn’t work since you can make the data connection and get MTP.
Do thumb drives, cameras, etc., work on that USB port? Just curious.
The USB 1.0 drive might have been the problem on your previous computer. The Fuze can be touchy about those.
And the original Win XP had a version of Windows Media Player that was the one before the Fuze-compatible one–IIRC, XP had WMP 9 and the Fuze wants 10 or above.
But it’s really surprising that on a newer computer, with a faster USB port, you can’t get the MSC connection, which is more direct.
If you want to continue using MTP, you might have fewer problems if you update Windows Media Player. That should install an MTP driver that reads the Fuze permanently, so you don’t have to keep doing the workaround. Microsoft Support also had something called an MTP Porting Kit that used to help people with XP and might also improve Vista.
http://www.microsoft.com/en-us/download/details.aspx?id=19153
Holy Misunderstanding, Batman!!!
Sorry you took offense, none was intended. As Bugs Bunny used to say, “Unlax!” It’s all good! ![]()
